IN1 / IN2 sometimes lose signal edge
I'm using a fibaro smart implant ( FW 5.2 )  to control my garage door. IN1 is used on a push button ( momentary button ) for opening / close the door and IN2 is used with a reed sensor to check the the door status
The main issue i'm experiencing is that sometimes, especially the IN1, remain breached nevertheless the real status of the input.
Now the status of the IN1 is breached but in reality is not. Already checked with a multimeter. Seems that sometimes ( 1 over 15 times ) the fibaro do not see the signal transition and it remain in a wrong status.
The button "Scena Ingresso Garage" was released quicky but the system believe is still engaged. Input sensitivity has been set to 10 ms but I even tryed different settings with same results.
Any advice?
Raffaele
This is a bug. Having the same. Any other smart impants around?
    Last months it worked 8 over 10 fine so not perfect ma reasonably good, today I was at home and I spent all day on this issue.
    First of all I done a range test and as expected the smart implant do not reach the HC3 directly but over routing. Quite reasonable since the flat is around 140 m2 and the garage is on the opposite side of the HC3.
    As soon as I check, without scene intervenction, the two inputs ( Scena Ingresso Garage and Stato Porta Garage  ) works flawless on tens of test. As soon as I do in conjunction with the scene the switch "Scena Ingresso Garage" or the gate reed "Stato Porta Garage" starts to behave erratically. It seem in cojunction with "heavy" zwave traffic some message between sensors and HC3 are lost and once lost are not retrasmitted and the status remain inconsistent.
    Is it possible? In a modern network I would say no but it seems happen on Zwave network. A Zwave range extender could fix this issue?
    Raffaele
    Edited by Fyase
    Did you have any progress with this issue? It can be a similar thing that I'm expiriencing:
    I'm changing my momentary switch time to auto off for 2s
