Cześć,
może ktoś zobaczyć co jest nie tak w tym kodzie że nie mogę zmieniać kolorów  i dodać efektów?
l
-- Color controller type should handle actions: turnOn, turnOff, setValue, setColor
-- To update color controller state, update property color with a string in the following format: "r,g,b,w" eg. "200,10,100,255"
-- To update brightness, update property "value" with integer 0-99
function QuickApp:turnOn()
    self:debug("color controller turned on")
    local http = net.HTTPClient()
http:request("http://192.168.0.253/win&T=1")
function QuickApp:turnOff()
    self:debug("color controller turned off"
http:request("http://192.168.0.253/win&T=0")
-- Value is type of integer (0-99)
function QuickApp:setValue(value)
    self:debug("color controller value set to: ", value)
    self:debug("TEST", value * 2.55)
    local dim = string.format("http://192.168.0.253/win&A="..value * 2.55)
     http:request(dim)
        self:debug(dim)
    self:updateProperty("value", value)
function QuickApp:setColor(r,g,b,w)
    local color = string.format("%d,%d,%d,%d", r or 0, g or 0, b or 0, w or 0
    local kolor = string.format("http://192.168.0.253/win&R="..r.."&G="..g.."&B="..b)
    self:debug(kolor)
    http:request(kolor)
   -- self:debug("color controller color set to: ", color)
    self:updateProperty("color", color)
function QuickApp:ONr(event)
http:request("http://192.168.0.253/win&A=253")
function QuickApp:REDr(event)
http:request("http://192.168.0.253/win&&R=255&G=0&B=0")
function QuickApp:GREENr(event)
http:request("http://192.168.0.253/win&&R=0&G=255&B=0")
function QuickApp:BLUEr(event)
http:request("http://192.168.0.253/win&&R=0&G=0&B=255")
function QuickApp:OFFr(event)
http:request("http://192.168.0.253/win&A=0")
function QuickApp:testr(event)
http:request("http://192.168.0.253/win&FX=55")
function QuickApp:staticr(event)
http:request("http://192.168.0.253/win&FX=0")
function QuickApp:button5_1()
self.http = net.HTTPClient:request("http://192.168.0.253/win&A=253")
function QuickApp:button5_2()
self.http = net.HTTPClient({timeout=3000})
-- Color is type of table, with format [r,g,b,w]
-- Eg. relaxing forest green, would look like this: [34,139,34,150]
-- To update controls you can use method self:updateView(<component ID>, <component property>, <desired value>). Eg:
-- self:updateView("slider", "value", "55")
-- self:updateView("button1", "text", "MUTE")
-- self:updateView("label", "text", "TURNED ON")
-- This is QuickApp inital method. It is called right after your QuickApp starts (after each save or on gateway startup).
-- Here you can set some default values, setup http connection or get QuickApp variables.
-- To learn more, please visit:
--    * https://manuals.fibaro.com/home-center-3/
--    * https://manuals.fibaro.com/home-center-3-quick-apps/
function QuickApp:onInit()
    self:debug("onInit")
    self.sock = net.TCPSocket()
