Temperature from climate setting not communicated correctly to devices
Guest theoverriet
Since update to 5.101 Beta the temperatures I have set in climate settings are not always communicated correctly tot the Donfoss thermostatic valves. If temperature is set to 21.5 degrees, the danfoss receives 21 degrees. So the .5 is lost.
UPDATE
The day after everything works fine. So probably a issue with default values?
Edited by theoverriet
Temperature in my case (23.56) in detail view (Chrome latest version)
/monthly_2022_03/image.png.c29834de38feccbd6b6b2d7900c875ff.png" />
  • Guest changed the title to Temperature from climate setting not communicated correctly to devices
