Alarm: Added checking sensors status before arming the alarm.
Any more insight on how this work?
How is the status checked and what will happen if an sensor is in breached when trying to arm?
There are 2 cases:
1. Arm delay set on the zone -> after counter alarm will be triggered (example, you did not close the door in time after arming the alarm)
2. No arm delay set on the zone -> system will ask if you want to force arm the zone, if arm it on demand it won't trigger the alarm (example, you left window opened on purpose on the second floor of the home).
Change is backward compatible with mobile app so there won't be any issues there, in the app for now it works as before.
Great function.
But do you have to activate it? Because it doesn't work for me.
When no delay set I didn't get a warning,  not by app and not by browser interface.
It will also be nice when the alarm popup, to disable alarm, comes up while entry delay is activated and not only when alarm already breached.
