Water consumption meter
Hi
Can you  recommend a Fibaro compatible device for control the water consumption?
5 answers to this question
Which Fibaro gateway do you have?
And what kind of water meter do you have?
I’m also interested ?
I have an old analog one …
HC2
    Hi
    I have HC2 and HC3,  and now I want to measure water consumption
    HC2
    If you have a watermeter like this, you can measure the water flow with a very simple (1 euro) HALL sensor, Raspberry PI with all-in-one ztatz.nl software and Quickapp for Fibaro HC3, see:
    /monthly_2021_10/image.png.159441c149af834275d42e17a696adfd.png" />
    See this PDF for more info:
     (please translate from Dutch)
    Thx @SmartHomeEddy I will certainly take a look. Nederlands is geen probleem ?
