Neo Andersson 232
Hi
Is there anyone who would tell me why can't Fibaro HC3 read Aeotec Trisensor Illuminance reports? They are not working with Fibaro. I can get the motions,and temperature but light is not reported.
Maybe a Fibaro expert can give me some hint what to do?
THanks in advance
EDIT
For those who were walking in my shoes i figured out what was the problem:
Illuminance and temeperature are not reported at all, if your wake up time in Fibaro is not set or set to 0.
Doesn't matter if you enable selective reporting in parameter 40, and set parameters 41-44 to desired treshold value. It doesn't count, becuase illuminance and temperature are reported exclusivly on wake up event.
The situation is different when your sensor is USB powered, or direct powered. In this case all the reports are beeing sent every 10 second.
Edited by Neo Andersson0 answers to this question
