How can I dimmer a Dimmer 2 device from another S2 input of another Dimmer 2 device with LUA scene?
 Hi I can´t dim a Dimmer 2 device from another S2 input of another Dimmer 2 device with LUA scene? I want to achieve dim at the same time that i hold the key connected in S2 input of another DImmer 2 device the other Dimmer dim at the same time, not after the release the key. Thank in advance.
Below i write the code that i´m used but i cannot do it work with good performance. Thank in advance.
i=0;
while (tonumber(fibaro:getValue(13, "value")) ~= tonumber(fibaro:getValue(7, "value")))
do
  if(tonumber(fibaro:getValue(13, "value")) > tonumber(fibaro:getValue(7, "value")))
  then
  i = fibaro:getValue(7, "value");
  i = i + 1;
  fibaro:call(7, "setValue", i);
  print("El valor de i es:", i);
  if(tonumber(fibaro:getValue(13, "value")) < tonumber(fibaro:getValue(7, "value")))
  then
  i = i - 1;
Sorry for my english.
