I am looking for a smart lock that can connect to Fibaro. It is also important that the smart lock is small and looks good. The tedee lock (
) meets my needs, but I wonder if an alternative is available. Can anyone recommend something?
NUKI, Danalock (Z-Wave).
Jakub mentioned correctly, but there are some bugs and requirements that need to be mentioned.
Danalock can't be included in S2 configuration, if you not running on Zwave 3. (probably you are not). It can be added in S0 configuration, but after like 1 month of fighting, we still couldn't get steady and reliable state reports, when there
are more Danalocks in the system. It can work, if you include your Danalock as the very first devices. This is also confirmed from many sources.
NUKI - it needs separate HUB. It dosn't work as a standalone ZWave device. NUKI-PRO can work alone, but it is not yet reachable on the market.
There is one recommendation from M.Roszak (Fibaro member). TEDEE TCP/IP based lock. It has full support in Fibaro.
At this moment I dont recommend Danalock, if you are using S0 security configuration.
I have been using Danalock V3 since December 2018 and it works great on my HC2!
Hope it helps!
R
We tested it on HC3. Contected Danalock support. I have some chat with many guys here on Forum, and i can say for sure, that it doesn't work properly on HC3, with S0 configuration. The more Danalock you have in system, the worse is the reporting of statuses.
There are some suggestions, that if Danalock is included to the system, as the very first device, it might work.
Hope it helps!
R
Same here but Gerdalock V3 - but its same yes?, very good work on HC2 since 2017/2018 without any problems.
