I "stole" a piece of code from @jgab and i'm trying to make a label where you can put in a timevalue like "12:50"
So far so good.
I need to determine the length of a string but that doesn't seem to work.
When i debug "lengte" i get a nil value.
Edited by Lode
  • Lode changed the title to Length of string
Your fibaro.debug is  the problem - it needs a  tag as the first argument.
fibaro.debug(__TAG,lengte)
Now it takes your length argument as the tag and it will not show....
__TAG is usually bound to  "QUICKAPP"..self.id
Because you are passing self to add you can also use the QuickApp  method debug that doesn't use a tag.
self:debug(lengte)
If you do a lot of   coding I would recommend that you use my offline HC3 emulator where you can debug the code properly on your PC/Mac
    Thank you so much for helping me out again @jgab
    I really appreciate this.
    Another tip.
    When you exit the QuickApp:onInit() function , the global lua variable 'quickApp' is  assigned the QuickApp object (aka 'self')
    This means that you can do
    The only reason to pass  around self is if you have a lot of QuickApp objects (ex. if you have QuickAppChild objects).
