can someone check it?
Create a block scene with the push message. Then convert this one to LUA. Now you have a correct working code.
In my HC 3 I get somthing like this.
hub.alert('push', {[1] = 846, }, ' Here goes your text', false, '').
The "hub" is the new syntax after an update
Edited by Flash
If you open you need to close too!
so add
//Sjakie
    so add
    //Sjakie
    typo ;) on forum,
    hub.alert('push', {[1] = 846, }, ' Here goes your text', false, '') -work
    hub.alert("push",{20},"text") - doesn't work
    @marczu@Sjakie
    I think there is something wrong with the push message's
    The messages that used befaore don't work anymore.
    Error
    (load):8: Assertion failed: Expected string
    If you convert a block scene to push it works.
    If you type in LUA hub.alert then enter to see syntax ist doesn't work.
    Startet after update to beta 5.102
    We are working on it :)
    thanks for the report.
    • Thanks 2
    same with email.
    38 minutes ago, K1_check said:
    same with email.
    sure, because it is the same function responsible for. The syntax has changed, it is now:
    Hi @tinman ,
    From where do you get this new syntax information? Can you please enlighten me since Fibaro is so f*ing bad in updating manuals.
    I'm just looking at the
    and there is still this:
    Or I'm just looking at the wrong place?
    each Fibaro firmware contains list of changes to the SDK / API, that list is readable from ssh level, which i have to my HC3, that's why i know it.
    Normally (it was list that last year), each time Fibaro changed something, the manuals page got updated
    no, you are too old :P
    it is proper place, Fibaro just not updated yet the docs
    True! :-D
    I do hope they update it soon, which means ASAP :-)
    I don't have it, but I guess I could ask to get it. I do have it for my both HC2
    Ok, so the ’fibaro.alert’ have been changed to ’hub.alert’. Seems like the old command was supposed to work but apparently aren’t.
    That raises the question: What about other commands like ‘fibaro.call’? Seems like there is a ‘hub.call’ command, will all commands change from ‘fibaro.xxxx’ to ‘hub.xxxx’?
    fibaro.alert and hub.alert works the same, the issue is with backward compatibility with *.alert function after some improvements there.
    We already fixed that and next version will restore compatibility (one argument less).
    @m.roszak
    Ok, but what about the general question i had?
    Will ‘hub.xxxx’ eventually replace ‘fibaro.xxxx’ ?
    Asking if it would be a good plan to already now start converting all scenes from using ‘fibaro.xxxx’ to ‘hub.xxxx’?
    48 minutes ago, JcBorgs said:
    @m.roszak
    You can do
    at the beginning of your scenes/QAs and continue using fibaro. If they start to change the names of the actual methods... well, that would just be mean ;-)
    It replaced it already... but, backward compatibility will be maintained so rewriting the scripts won't be necessary - ever :)
