Variable not updated
Lode
I don't understand what is wrong with this code.
The variable  v_AlarmOn is not updated.
The variable  v_Test is updated.
The value 'attempt' is correct.
4 answers to this question
Who is calling and when is QuickApp:Opslaan() called?
  • It's a piece of your code @jgab ? which i changed to my needs. (thanks)
    Opslaan is called by pressing the button Opslaan.
    It used to work when i was playing with HC3 the first day.
    Yesterday i did the migration-thing and downloaded, uploaded the quickapp and now it doesn't work.
    Maybe you can take a look....
    If your v_test is updated your v_AlarmOn should also be updated. In the QA the variable is named 'v_AlarmAan' - are you looking at the right variable?
  • I was looking at the right variable but it's strange.
    I just made that variable in General/Variables and there it is updated.
    In the list of variables from the quickapp it's not updated.
