VMatas 0
Seems I have some problems with my setup stability. Setup is as below:
1. HC3
2. 5 groups of lamps, from 2 up to 5 lamps per group(total 21 lamp). Each lamp has its own dimmer(Qubino). Each lamp can be dimmed separately from HC3 without any problems.
3. Each group of lamps has its own dimmer(Fibaro dimmer 2) with monostable switch(on/off, held for dimming, 2 times click for max). Qubino dimmers are controlled through Fibaro dimmer associations.
Problem:
When Fibaro dimmer is added to network and associations for appropriate Qubino dimmers group are created all things are ok, on/off, dimming, double click functions are working as expected. But after few days problems will appear: on/off is working with noticeable delays, dimming function has strange behaviour - instead of slow dimming lamps brightness in about one second is going to zero and lamps are off, double click isn’t working at all. If I remove whichever of Fibaro dimmer from network, then reassign it and add associations - for some time that group works as expected.
So question is - what mistake I have made? It is problem with HC3 load or something else? May someone can comment this situation?
