Wiring single switch in a 3-way switch configuration
I have a 3-way switch in my home which is wired as shown in the linked diagram. I only have access to L2 and S1, at the other switches and lamps I don’t have the space and access to add a Zwave module.
Preferably I would like to use Fibaro Switch 2, but all diagrams I find you’ll need to connect the module between the last switch (S3) and the first light (L1).
Could someone advice me about a solution?
Btw I am able to add a neutral wire at S1 or live wire at L2.
You can find the diagram of the situation here:
