How to identify running scenes in HC3
In HC2 you had this view of running scenes
/monthly_2022_04/563765998_Skrmbillede2022-04-10kl_09_26_59.png.58b0f4ee8774c969b9ba5e0cf128fbe7.png" />
In HC3 you don't. You can't even use a "hub.countScenes" because there's only max one running instance of a scene  -which is fine of cause. But still: How do you check if a scene is actually running? How do you confirm that a kill action was executed correct? There's no view in HC3, and there's no LUA command to get the status of the scene (only active/inactive, which is not the same).
One could do something like this - a QA that monitors the Scenes running and ending...
(using the fibaroExtra library)
