Jay Age 0
I have a Fibaro door sensor FGDW-002 and a Fibaro Double Smart Module FGS-224 in my environment with a Home Center 2 (Firmware 4.620). I have configured a direct association in the door sensor that is turning the Switch 1 of the Double Smart Module off after 5 seconds when the magnet is away. And when the magnet is back the switch 1 of the Double Smart Module is going to be turned on after 1 second. I made the direct association because I want a fall back when the Home Center is not aviable for any reason. So far so good, everything works fine as long as the Home Center 2 is up and running. As soon as the Home Center is turned of the direct association does not work anymore.
Door sensor associations EndPoint 0 Group 1:
/monthly_2022_04/694974299_Door-SensorAssociationGroup1.png.eb9241259a3fdc3aaa866161b64ac4fe.png" />Door sensor associations EndPoint 0 Group 2:
It would be great if someone could give me an advice how to configure the direct association that works when the HC2 is unaviable.
Thank You!
Edited by Jay Age2 answers to this question
