Sunset in Belgium today is 20:24.
SunsetHour gives 19:41.
Timezone in HC3 is correct (Europe/Brussels)
Edited by Lode
I expect it to be based on your location, not timezone.
    Location was also correct.
    HC3 behaves a little bit like HC2 ?
    Just wait for a couple of hours and it's ok.
    Now it's correct
    Edited by Lode
    @Lode,
    I'm teaching in our Fibaro training to use following Quick Apps.
    If solar height is between >-6 and <+6 and azimuth (position) is < 180 then it is sunrise.
    If solar height is between >-6 and <+6 and azimuth (position) is > 180 then it is sunset.
    PS: I did not learned, yet, to work with child devices, so it is basically same code with just different values as output.
    • Thanks 2
    You're a genius ?
    @Lode,
    Forgot to mention. It is plug&play. Both Quick Apps rely on correct setting of HC3 location in Location tab in General panel.
