HTTPS GET request on Fibaro Home Center 2
I have a code I wrote in Lua, which gave me a response of prices and timestamps, I want to do the same in HC2, but the request function is a bit different than the one on Lua. How can I request prices and timestamps and insert prices into one table and timestamps into another table? I understand I need to use the GET request to get the responses from the web-API.
URL:
 what I want the output to be when I print them out:
Edited by Joohane
5 answers to this question
Looks like the same post like:
But then is was suspected to be a HC3
    It looks like the same post, but this time I clarified more, to how I wanted it to work. I know I messed up when I wrote the last question, and didn't explain what I wanted it to do, so I tried doing it better with a new post. Couldn't find out, if I can or how to delete a previous post.
    Just like the Tibber quickapp for the HC3, there were initiatives for getting price information from Tibber on the HC2. To get a picture how difficult it could be see those posts.
    See:
    And also see:
    But it won't be easy to make a new one for your dashboard.elering.ee if you are not acquainted with the HC2 virtual devices, HC2 scripts and Lua.
    See:
    And also see:
    All right, I'll try to follow the instructions from the websites you quoted here. I just have one concern, and i'm wondering, if I'm able to use my API URL instead of Tibbers API URL.
    Edited by Joohane
    That is definitely not an easy task. I wrote several other quickapps for the HC3 before I wrote the Tibber quickapp, that wasn't an easy task either. Depending on how you want to arrange your appliances, you need the current price, the lowest price, the next hour prices, percentages plus or minus of the next hour prices, etcetera.
    I am not that acquainted with HC2 virtual devices, I think https needs to go with een script in combination with a VD. I hope other people on the forum can help you out with that. It is worth a try, you can save a lot of money? and energy? with it, but it is not the first HC2 thing to start with.
