Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. System supports adding of the Nice, Elero and Z-Wave devices from mobile application*
Additionally new Z-wave devices adding procedure in webUI is introduced.
2. Introduced new way of controlling devices using dialogs on Favorites screen in mobile application
3. New Scenes category called "Scenarios" for easy control of shutters and blinds according to sunset and sunrise triggers
Possibility to configure "morning" and "evening" scenarios with few clicks.
System supports altering configuration of those Scenarios via mobile application.
4. Zigbee protocol support (Home Center 3)
First public beta version of Zigbee protocol support now available for tests purpose on HC3.
Support for limited types of devices with focus on lighting.
Important:
Philips TV and Samsung Smart Appliance plugins are no longer supported and have been removed.
What's new:
Alarm
Added checking sensors status before arming the alarm.
Dashboard
Added translations for thermostat modes on dashboard tiles and sidebar.
Added possibility to open device settings directly from device tile.
Improved styling of units for sensors on dashboard and sidebar.
Changed icon for opening sidebar from device tile.
Added logs on device tiles related to transmitting commands for Nice and Elero devices.
Devices
Updated parameters template for Nice BiDi-Shutter and Nice BiDi-Awning.
Added support for Eurotronic Air Quality Sensor.
Improved handling of long operations for Color Controllers and Multilevel Switches.**
Added support for new revisions of Fibaro devices.
Default configuration for RGBW441 set as RGBW after adding device to the system.
Added rounding for virtual power consumption values.
Added support for Donexon thermostatic valve.**
Custom parameters for Z-Wave devices sorted by ID.
Support for MCO ZW700 series devices.
Improved handling of hold actions on sidebar buttons for shutters and venetian blinds.
Elero*
Improvements for pairing process.
Improved polling mechanism for Elero devices.
Improved support for Elero Dimmer.
Modified descriptions for pairing process.
Added possibility to pair unknown device type to the system.
Energy
Warning about unsaved changes in Panel Settings.
Added support for declaring fixed cost for a period.
General
Optimized calculation of sunrise/sunset time.
Network
Improved changing network settings between DHCP and Static.
Nice*
Added possibility to Read, Set default and Reset all parameters in devices settings.
Changed default role for mono-directional devices from remotes to Blinds/Gates.
Added requesting current parameters values during pairing process.
Added possibility to configure and use favourite position for mono-directional devices.
New styling for Nice devices pairing process.
Improvements in protocol auto-detection function.
Improved support of BiDi-Shutter and BiDi-Awning devices.
Added possibility to calibrate BiDi-Shutter and BiDi-Awning devices from settings.
Added notification about issues during device configuration after paring.
Added displaying favorite positions states on BiDi devices.
Other
Improved auto-logging feature.
Plugins
Thermostat & Heating Zone plugin optimization.
Added possibility to set the URL manually for Dahua plugin.
Reorganisation of plugins categories.
Profiles
Support for new "Scenarios" in profiles.
Quick Apps
Changed function calling format (backwards compatible).
Changed auto-complete function for new function format in Lua.
Added possibility to edit "secret" variable in QuickApps.
Scenes
Changed functions calling format (backwards compatible).
Changed auto-complete function for new functions format in Lua.
Added icons for group actions.
Changed font color in dark-mode of Lua editor.
Added possibility to enable or disable the scene from edit window.
Update
Added reconfiguration button for device after successful update.**
Z-Wave devices update process improvements.
Z-Wave
Improved handing of communication errors.
Optimized service start-up.
Updated certified Z-Wave manufacturers list in Z-Wave engines.
Improvements for Z-Wave database size management.**
Bug fixes:
Alarm
Unnecessary notification about wrong pin when trying to disarm the system.
Cameras
Inactive camera preview tab after saving device settings.
Dashboard
No automatic refresh of color components on device sidebar.**
Missing polish translations for states of simple shutter.
No automatic refresh of power consumption on devices sidebar.
Fixed issue with displaying states for shutters on devices sidebar.
Devices
Missing barrier role for simple shutter device type.
Issue with adding Fibaro devices (Wall Plug UK, Smart Module, BiDi-ZWave) in Security Mode.
Rejected association settings visible on the list until page refresh.**
Power graphs in advanced tab do not scale when zooming.
Uploading custom icon for Fibaro CO Sensor not possible.
Cannot change parameters in Z-Wave devices if "use template for parameters" is disabled.
Issue with opening 1P Smart Meter Qubino configuration.**
Incorrect devices grouping on settings page for QuickApps and Linked Devices.
Additional not applicable icons for devices.
Redundant device roles for Walli Roller Shutter and Roller Shutter 3.
Inputs state for Smart Implant not reported correctly.**
Devices added via Smart Start are not visible in the system until reboot.**
Protection settings for Z-Wave devices fixed.
Issues with thermostats support when using climate panel.**
Diagnostics
Issue with starting reconfiguration from Z-Wave tab.**
CPU graphs issues.
Elero*
Wrong device configuration if timeout occurred during binding procedure.
Issues with controlling devices after update from 5.072.25 beta.
Energy
Wrong rounding of percentage consumption on Savings tab.
Production devices listed on Top consuming devices and on devices list on Savings tab.
Excluding production devices from the Energy Panel does not work.
Gateway Connection
Changing Fan Mode for thermostats from slave gateway is not possible.
General
Home location settings change does not alter sunrise/sunset calculation.
Location map does not show if longitude/latitude is out of range.
History
Device icon does not correspond with the state from history.
Network
No information about possible connection loss after changing network settings.
Internet connection status is not stable.
Nice*
Not migrated device roles for Nice Mono devices added in the system on 5.080.
Nice Mono devices added on 5.080 lost the icons after updating to 5.100.
Issue with pairing some Nice Mono devices.
Notifications
Devices icons in wrong states on notifications list.
Non-admin user cannot remove notifications.
Other
Additional credentials popup during log-in in some cases.
Text in reboot modal not centered on Safari browser.
Rejecting custom icons upload if file extension is in uppercase.
Issue with booting up the hub after update to 5.101 Beta.
Nice and Elero devices not counted in number of devices in backup.
Plugins
Removed additional button on sidebar for Fibaro Intercom.
Impossible to configure EnvisaLink plugin.
Profiles
Using Walli devices ring actions causes system crash.
Quick Apps
Partially white background in mobile view in dark style.
Fixed visibility for functions declarations.
Scenes
Scene does not start in specific configuration when trigger is used in few scenes.
Differences between calls in Scenes and QuickApps.
Fixed visibility for functions declarations in Lua code.
Update
No translations of errors for devices update service.**
Known issues:
Nice*
After adding Nice device page refresh is required.
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - Requires the latest 1.16 version of Yubii app
** - applies only to Z-Wave Engine 3.0
