Anth 11
All,
just made a 3D printed enclosure for two dimmer modules. Designed to be fitted into drywall with plaster to be formed around the edge
The lower section holds the two dimmers, bypass blocks and wago terminals for active and neutral. Top section contains wago connectors for active, neutral and earth as well as the two load actives. Top also has four holes for cables in and out as well as the two load cables.
Wires to the Clipsal Saturn switches are connected via plugs and sockets for ease of use.
Anth
6 answers to this question
