Hi All,
I'am pretty new to fibaro and HC3.
I am running a RPi4 flashed with the Ztatz firmware for the P1 meter.
Then installed the P1 QA P1 Monitor, and configured it.
It all seems to be running quite smoothly, but, I think I have my production values doubled for whatever reason... and I have no clue why.
The P1 Monitor hosts a small webpage itself showing me todays production of 03.887 kWh.
The HC3 energy panel shows me almost 7.77 kWh (There is a little bit of time between the screenshots)
Why is the energy panel showing me a production of 7.77 kWh ??
I set HC3 Main energy meters: to "Meterkast | Todays Consumption"
Now, who can give me a push in the right direction, I would really like to have the same / correct values from P1 monitor shown in my energy panel.
Thanks!
Edited by Neoster
Hi @Neoster
In the advanced settings you can manage the child devices to put the values in the Energy Panel. Check all child devices and only put the values of the child device "Todays Production" to the energy panel.
So only these setting for Todays Production and for all other devices disable this two V under Energy production.
(And maybe you also have other QuickApps running who put values in the energy panel)
Edited by SmartHomeEddy
    6 hours ago, SmartHomeEddy said:
    Hi @Neoster
    Hi @SmartHomeEddy
    That makes sense and actually was the case. I checked the boxes for Production High and Production Low as well as I thought it meant that the data would simply be visible in the energy panel.
    In a certain way it was, but not how I interpreted it :)
    I guess this will fix it, tomorrow we will know for sure.
    Is there a way to clear the engere panel database so I can make a fresh restart with no history?
    Thanks!
    Yes, in the panel settings, you can delete (some of) the energy values.
