Update went well, apart from unresolved issue with Sensative
The update from 5.100 to 5.110 of master HC3 and slave HC3L went well. So far, no issues.
Average RAM usage (72%) seems to be higher than before.
The only issue I have after every backup and every update, is that all my Sensative strips that are on the slave give the wrong status as soon as they wake up.
So a day after the update, I have to walk around and open & close every window, to get the correct status again. Once that is done, it doesn't happen again. Until the next backup or update.
This happens only with the strips that are on the slave; the strips on the master behave correctly.
Edited by marcwau
Additional info
  • Thanks 2
