FIBARO System Update 4.620 for Home Center 2 with Yubii 1.16
Hi All,
Is anybody seeing all the new features in Yubii 1.16 app........I am running an HC2 connected with 4.620 as I am not seeing any of these new features.
I have done the following.
  • Deleted the Yubii app on the iPhone and reinstalled it
  • Restarted the HC2
  • Interesting that when I deleted the Yubii app from the phone and reinstalled it I saw add devices on the Home Screen but it has since disappeared and I can not rename any devices from the app
Beeker
same here i suppose is available only on HC3 and Yubii hub, or maybe only Yubii hub
    I think your right
    @K.Drozynski
    I DO HAVE THE SAME PROBLEM!
    On my smartphone (S8+, 5 years old) I installed both apps Fibaro HC2, since 2019, and Yubii last year. (have alook to my signature for my hardware...)
    The use of Fibaro HC2 is smoothly, I can use it to add/remove Devices, have push and popup messages (PopUp are stored on my Phone and I can keep the history as long as  necessary), I program my scenes to send popup or push messages according to my needs...
    but Fibaro HC2 is not stable in geoFencing !
     mean that it does not update position to HC2 even if i set to 1 minute... this function is unstable (maybe to many passages from the phone, to the Fibarocloud and then to my router and finally to HC2....)
    The use of Yubii in connection with HC2, is not peaceful, the only think is that it works a little bit better geofencing..... but sometimes also Yubii  forgets to update HC2 at home,
    I have Scene which provides  popUp messages, but they are managed as Push messages only.
    The problem is that my Wife has S20+, and the Google Play says that the App Fibaro HC2 is not compatible with S20+,  so  she is compelled to install Yubii only, with all problems  described on Google Play store and here in the Blog....
    Edited by Giovanni_Genoa
