Mike MJ 3
Using a HC3, has anyone been able to set up a Thermostat [Settings>Devices> Other> Thermostat] to control a reverse cycle air conditioner in either Heating Schedule or Cooling Schedule. When I set this up I get very erratic cycles of on and off without any apparent pattern to the activating temperature.
However if I set up the Thermostat with only one temperature sensor and one on/off switch using only a heating schedule it works fine. My problems arise when I try to have 2 scenes setup ...one to operate a heating schedule and a second scene to operate a cooling schedule . Even when the cooling schedule is disabled the system behaves erratically .
Any advice will be appreciated.
