Desde la actualización 5.110.15 mi termostato quedó en dispositivo desconectado, se quitó de mi hc3 y ahora no puedo volver a agregarlo, es como si no lo reconociera, ¿a otra persona le pasa? ¿alguna solución? Gracias.
There has been some issue with ZW3 and TRM3 for some time now, and I am not able to control my TRM3 using climate panel.
Still hoping for a fix for this soon…
Have not tried reinstalling with the last version, but if you have troubles adding TRM3 still you can try hard reset on it. That has helped me in the past.
By pressing buttons Right and Center (down and confirm) for 20 seconds, the thermostat will perform a complete factory reset. The device will display rES for 10 seconds while performing a factory reset.
    I recovered a previous version and it started working again, then I updated again and it is working perfectly, even in the climatic panel. version 5.110.15
