Will Fibaro products bought in UAE work in India?
All,
I have purchased Fibaro products from UAE and now I am moving to India. I am concerned if the products will work in India? On research, looks like these devices might work on different frequencies?. Form the product page of Amazon it says on the 2 channel - relay "8684 MHz radio frequency for use in 47 member countries of CEPT (including whole of EU), plus China, Singapore, South Africa & UAE" and in India the same product on Amazon, it says it operates on 865.2 MHz Frequency as authorized Indian Freq per the law.
Let me know if I can use these products in India from UAE. Kindly help.
The list of Fibaro products I have are listed below (hope all work in India in not then atleast the Swipe and the hub).
  • Fibaro Home Center 3
  • Fibaro 2 Channel Relay
  • Fibaro Swipe
  • Fibaro Dimmer
  • Fibaro Fibaro RGB Controller
  • Fibaro 4-in-1 Sensor (Motion+Vibration+Lux+Temperature)
Thanks!
Hello
Like you saw in UAE products use different frequency, they will work in india but like you wrote by law this freqency is prohibited and can be jammed by LTE, all z-wave product sold in this market are sold with 865,2MHz freqency ,so will not work with your HUB. There is no option to change frequency on products
