fantomas 0
Hello, how to read an "advanced" parameter that needs "read only" flag in order to be updated?
I was able to get the values of interested parameters with following code, but the values are "last read" values and not the updated ones. I am trying to read produced and consumed energy from a Widom energy driven switch, but the device template is not fully implemented and I need to add 2 advanced parameters (54 and 55) that contain produced and consumed energy readings.
Unfortunately the parameters need to be set as readonly (in device interface) in order to get them updated.
Is there an alternative way to read advanced parameters 54 and 55?
device=api.get("/devices/" .. 174)
local parameter1
local parameter2
for _,v in pairs(device.properties.parameters) do
if v.id==54 then
parameter1=v
elseif v.id==55 then
parameter2=v
break
fibaro:debug(parameter1.value)
fibaro:debug(parameter2.value)
