Hello
I wanted a slim one without on keyed function for a script. I have derived some things from the forum and tried but it shows constant gaps in the last number. Example 1,2,4,5, 7 and so on.
Can anyone send me a post with a reliable radio.
Die von jgab und cag014 are strongly branched for me.
Thank you in advance.
Sorry, need more info to understand what you want.
Do you have some example code?
    Hello with Google translator the only way to rent me out I hope I can get further.
    I want a simple trigger to then continue on my own.
    "single instance / event"???
    When starting and displaying the last update, it keeps skipping several counters.
    [DEBUG] 14:25:43: 17677
    [DEBUG] 14:25:44: 17678
    [DEBUG] 14:25:47: 17680
    [DEBUG] 14:26:00: 17681
    [DEBUG] 14:26:01: 17683
    [DEBUG] 14:26:03: 17685
    [DEBUG] 14:26:04: 17687
    [DEBUG] 14:25:35: 17673
    [DEBUG] 14:25:37: 1767
    Edited by parip69
    That's normal. You will have multiple results in states.changes
    37 minutes ago, parip69 said:
    That won't work, because "lastchanges" only has the last ID of this loop, not every change of the loop:
    38 minutes ago, parip69 said:
    So I guess what you see PRINTED in debug is correct, but your "if myTrig.id == lastChanges.id then" is not IN the loop so it is not working.
    Move your test (and adjust its syntax, to match what you see in the debug window, printed by the "print(json.encode(v))" statement.
    This is totally undocumented, that's why you are struggling to make it work. What I am saying is this: you can make it work, but Fibaro might decide to change how it works any time
    44 minutes ago, parip69 said:
    Google translator
    Yeah, I thought so.
    It is totally unreadable :D
    But as soon as you posted "DEBUG] 14:25:43: 17677 [DEBUG] 14:25:44: 17678" I understood what you meant
    BTW I posted a similar loop, as demonstration, as a Quick App
    Look for the comment
    Below that line, you can put your test and decide what to do when that event happens
    Hope this helps, at the moment I am unable to try out your code and fix it. Sorry about that.
    Hi.
    I have an HC2.
    It is working. But I don't get any data out of the for loop. Can you make it a bit more flexible? I wished for a solution for HC3 script.
    Edited by parip69
    10 hours ago, parip69 said:
    I have an HC2.
    I don't have a working HC2 at the moment, it is kind of hard to test.
    add a
    print(lc)
    after the
    lc = v.data
    So we can see if the events have the properties that you expect...
    Also a good candidate to add more debugging is in function findID - print everything you get there and tell why it does not match.
    BTW what do you want to do? Why use refreshStates? Not many users on this forum do that. I do :D and I have my reasons (a complex lighting scene with lots of conditions.).
    If you want to get things done, and learn about "refreshStates" then you can have a look at this scene:
    I do not use the scene myself but I know @cag014well and he has written excellent code that is complex, but readable.
    Edited by petergebruers
    Hello petergebruers.
    That works with the print I get everything.
    I also know the scene of the @cag14. But don't use it. I would like to code a little myself. That's fun.
    Unfortunately, I can't write as elaborate code as...... the well-known ones from here.
    I just need to trigger them and then I'll get along. I also need for a college and it has an HC3 for Scene and not Quick app.
    Thank you
