5 unsuccessfull attempts later, any help welcome...
Each time I agree and start installing the latest upadte from 5.090.17 to 5.110.15 it stops later or sooner and states "There was an error in checksum validation."
Is there a tip, a fix, or a way to downlod on the PC and install frome this verified downloaded file ?
Thanks in advance,
Jean-Jacques
Hi @JJAA,
Try following:
  1. Download firmware from
  2. Set your HC3 to recovery mode.
  3. In midle there should be Repair System A/B.
  4. Click repair.
  5. Choose Repair from file.
  6. Select file you downloaded in step 1.
  7. HC3 should be updating to 5.110.15 and devices + scenes should be ok.
