Fabrizio1969 2
Good evening
I need some help with a block scene:
my system is made up of 4 led strips (4 rbgw2 controllers + 1 that I use as a switch to physically turn the other 4 on and off) I created a scene with the door sensor they light up blue and after 30 s they turn off, with a movement sensor the red LEDs turn on and after 30 s they turn off, now the problem if I press key 1 on the remote control to turn on the LEDs, these turn off after 30 s, the same when activating the movement scene, how to deactivate the door scene or movement when I turn on the LEDs?
I use a hc3
thanks and ciao
