QA does not loop
Hi
USING HC3.
I have a QA to fetch times of sunset and other calender related functions.
I have it on a 1 minute loop which works.
My issue is I have a function called GetTimes() saved in a sub sheet in the QA, if i add a line like this in the QA it runs once and then does not loop it self again with no debug errors visible.
What I can't figure out is I run the exact line of code elsewhere in the QA without getting any issues.
local hNewDay = GetTimes(currentTimeSec,sunDegree)
Could anyone shed some light on to how to find out what is going wrong and on how to fix this?
6 answers to this question
1 hour ago, Jay Ess said:
Hi
USING HC3.
Sorry, can you provide some example code - I can't really understand.
What do you mean with QA doesn't loop?
If you run a loop with setTimeout/setInterval, then you should wrap the function in a pcall so you can trap and print the error.
    what do you mean by pcal? will send snippet of the code
    function GetTimes(gDate,gAngle)
        local currentDate = os.date("*t")
        local year = tonumber(os.date("%Y",gDate))
        local month = tonumber(os.date("%m",gDate))
        local day = tonumber(os.date("%d",gDate))
        local hour = tonumber(os.date("%H",gDate))
        local minute = tonumber(os.date("%M",gDate))
        local weekday = tonumber(os.date("%w",gDate))
        T = getT(year,month,day,hour,minute)
        local GMT = 0
        if currentDate.isdst then
            if (weekday==5 or weekday==6) and month==10 and day>=24 then
                GMT = GMT
            else
                GMT = GMT + 1
        else
            if (weekday==5 or weekday==6) and month==3 and day>=24 then
                GMT = GMT + 1
        R = gAngle
        hour = "12"
        minute = "00"
        local returnTime
        if R == -8 then
            returnTime = wI(T,"U",year,month,day,GMT)
        elseif R == -0.8333 then
            returnTime = sec2str(str2sec(wI(T,"D",year,month,day,GMT))-(15*60))
        return returnTime
    this function retruns me sun times.
    this is my loop
    function QuickApp:loop()
        self:setHebrewDate()
        setInterval(
            function()
            end,
            1000 * 60 *1
    this is a nother funtion which gets called on the loop
    function QuickApp:setHebrewDate()
        local currentTime = os.date("%H:%M")
        local HebrewDayStart = (fibaro.getGlobalVariable("Sunset"))
    if i change the last line to HebrewDayStart = GetTimes(os.time(),-0.8333)
    i get the time of 20.16 which is corect but then the qa does not run again
    7 hours ago, Jay Ess said:
    Hi
    USING HC3.
    Yes, known issue that in some cases HC3 doesn't show the error and just restarts the QA....
    As I can see you haven't posted the entire QA code, so you need to find the error by your self....
    Another question - why you don't use built-in sunset value?
    Edited by cag014
    Do
    If getT() that we don't see call http:request you need to wrap the success/error handler in pcall also.
    @jgab thank you for that will implement it
    @cag014 yes found the error by putting a print line on each variable, took some time but found my error, one function needed 3 varibales and i was passing it 2 so the second variable which should be a number was a string and hence the crash although i dont understand why it ran some times, need to re-look at the code on a rainy day. I dont use the built in sunset times as need work out sunset with a higher degree of accuracy then the hc3 seems to be, need to be exact on the minute and control the roundup and round down, hence why needed my own sunrise and sunset time calculater.
    Thanks guys for you help now working as expected.
    function QuickApp:loop2Minute()
        local cLTime = os.date("%H:%M")
        local sec = os.date("%S")
        if sec == "00" then
            self:loop()
        else
            print("Seconds:",sec)
            fibaro.setTimeout(1000, function() self:loop2Minute() end)
    am running this loop on startup but i find that the qa seems to drift off the 00 second mark, how can i keep it to run on 00 seconds all the time and if it drifts off then to adjust back?
