mi38k 4
Hello, I have Walli Dimmer connected in 3-wire installation to a light with 3 dimmable LED bulbs (3x14W) and when I set brightness let's say below 50 %, I can see the light to slightly changing the level of brightness - like if the dimmer is having hard time to maintain the desired level. Lower the brightness set, the more apparent the fluctuancy is. It is not like flickering where the bulbs would be flashing, there are just a small changes in brightness. Is it normal? Would Bypass 2 help in this case?
In fact I have two exactly same connections in two rooms and both behave the same way.
Thanks in advance for any responses.
26 answers to this question
