cristicatalan 1
I tried to find answers to the following questions, but I haven't found a definitive answer.
I read that Dimmer 2 can have multiple uses, but I'm interested in normal light dimming. I want to set the brigthness only from the smartphone, but also use normal switches on the wall to turn the light on/off. I also want the dimming value to be to be programmed according to a schedule, and respected when operating the light switch manually. Sorry, I don't know some of the corect terminology and if the following use cases are possible.
