Qubino Flush Shutter on HC 3 to control Velux SML Roller Shutter
Im struggling a bit with the following setup:
HC 3 controller
3 times Qubino Flush Shutter
1 24V 10A mean well dc power supply
3 times Velux SML shutters
wall controller Heat-it zpush wall controller
I have the Qubinos linked to my HC and all 3 are appearing as 2 lines. So far so good.
Now I can change the parameter 78 (forced calibration) to 1 and the shutters move. The do a Close and Open. So not 3 times as indicated in the manual from Qubino.
I see still yellow triangles in the icon and the say "not configured". Also in the preview tab from HC, I cannot make the shutters to move.
What do I do wrong?
    Nobody has a clue?
    Have you connected Qubino Flush Shutter properly? does it work with the switches properly? in both situations if the switch holds down as that you press briefly?
    The Qubino Flush Shutter should work well I have 8 of them running in my home with no problems though on 230V but that should not be the problem.
    /monthly_2022_12/181089533_2022-12-0515_14_46-HomeCenter.png.ea1db550f453cb010cd3b0c030b8e16f.png" />
    Triangles are still a problem with Fibaro HC3 but you can ignore them, blinds function still works.
    Probably the motor is using to much power for the default setting and it thinks it already hit the end.
    Change parameter 76 to 100 (10W) and make sure parameter 74 has a high value ~400.
    Then try again.
    /monthly_2023_10/image.png.ee10e255cac3fa848db5fddb1fe2e8a5.png" />
    When the blinds are working you can lower these two setting to the wright value.
    In my experience setting parameter 74 to 0 (default) is not working. Always set a time that fully opens and closes the blinds also when there are limit switches.
