Hi i have problem with scenes in living room.
If i select living room, tahn cant select nothing device. If i change livingroom on another room, than fibaro change device on another room. If i change back on living room i can see only devices from last room.
First time repair: i create new living room and move all devices on him. i repair all scenes and work it.
Few day ago. i see same problem. scenes dont work and devices cant see.
This deal only living room. any idea why?
Do you using same login , I mean you logged as an  administrator?
It could happen when the user doesn't have the rights to the room or device or scene... please check access rights in Access Control.
By the way what gateway you're talking about? HC2 HC3....? or may be you refer to mobile application?
Please contact support if problem persists, we will check it out.
    On screen. HC3, admin rights.
    email: *********@gmail.com on HC3-******** . support login allowed.
    There is an issue with one of czech translations (if interface is set to any other language, problem does not exist).
    I fixed it on your gateway, general fix will be included in next update.
    • Thanks 2
