Hi, qubino smart meter (single phase) is now compatible with this version? Thanks
3phase version recieved support for all known versions.
1phase works but in version 1.0.
    Thanks for the reply m.roszak @
    So now with the vers. 1 does it support modification parameters with hc2?
    Currently I have mounted a WiDom Energy Driven Switch (ver. C) but I have to disable the item shows the measurement of energy consumption on each single device, otherwise the consumptions are doubled.
    Hi @m.roszak  My 1phase Qubino Smart meter (v 1.7) is working fine with 4.620 on HC2.   Will it still work if I update to 4.630 ?
    Edited by RobertL
    Sure
    It works like other similar devices (1phase).
    In short, it is always necessary to disable the consumption control of all the cascade devices, otherwise the values double.
    But is it possible that the modification parameters of this device are still not available years later?
    What balls!
    Edited by GasDeKu
