I am very conversant with the HC2 stuff.
For the HC3, the last time I looked at this a year ago, the offerings were rather disappointing with a steep learning curve.  Could some one recommend
  1. A decent example of a lua scene.  I am fine with the language change - I have just grepped and done global modifications on my 30 odd lua scenes.  I am looking for a better explanation of the new trigger mechanism.
  2. A decent example of the new VD and any gotchas.
  3. Before I could just save the lua as a text file on pc with versioning.  How are people saving the new scenes, as they come in two parts ?
I use EventRunner4 from JGab.
Here in I use QA's 5 pieces instead of over 100 scenes in HC2 herfage I save all my Home automation as .txt but you can also save as .fqa
VD are nou useable in HC3 >>replaced by QA
QA's you can save as .fqa much easier as saving in .txt
//Sjakie
1. For Lua scenes (and triggers) search the forum. Lots of information here, and to start check the documentation:
2. VD's are now Quick Apps, lots of information on the forum too, and check:
3. Learn to use
. (put the trigger/condition stuff above the scene code and you'll be fine.
What have you already tried yourself? Your question is very general and it feels like you don't feel like looking up basic information yourself. You have to show that you put own effort in it to get people helping you. ;)
