Mke 0
Hi All,
New Fibaro user, first time setting up Home center 3. So far inclusions and some basic block scenes are going well.
As a first step, I've decided to use block scenes and manual push buttons to get the home lighting up and running, currently no Lua experience
Generally, I have allocated 3 push buttons, TOP, MIDDLE, BOTTOM per room with the following functions:
TOP: 1 click - Lights level 3
TOP: 2 click - Lights level 4
MIDDLE: 1 click - Lights level 2
MIDDLE : 2 click - Lights Level 1
BOTTOM: 1 click - ALL OFF
As the lighting level drops from 4 to 1, certain lights turn off, and the remaining dim if capable.
I have just noticed an output i could assign to the "HOLD" trigger, could "INCREASE LEVEL"
The problem i can see, is that if trigger 12: "HOLD" is activated while lights level 4 is active, then 8 lights need to increase brightness.
But if trigger 12"HOLD" is activated while lights level 1 is running, then only 4 lights need to increase brightness.
So using block scenes, I am essentially trying to get two "DO THE FOLLOWINGS", with both sharing the 1 input trigger, id 12 "HOLD:"
Would anyone please be able to share some lua code to say: increase level of any of the following id's: 49, 54, 80, 85, 109, 110, 121, 156, 164, only if light is already ON? So would work if just 1, or all lights were on. but only increase dimiming of that 1 or all.
sample code with adding one light on as a condition:
conditions = { {
id = 43,
isTrigger = true,
operator = "==",
property = "sceneActivationEvent",
type = "device",
value = 2
id = 49,
isTrigger = true,
operator = "==",
property = "state",
type = "device",
value = true
operator = "all"
Thank you,
Mke
