  • 1 month later...
Same problem here, factory reboot to 4.630 works put when power down, HC2 no longer reboot.
All lights on HC2 go on on starting procedure, but after +- 10 sec ( Almost all light are continue on) All lights go off.
After a while HC2 tries to reboot itself but same issue over and over.
I do not have a file backup of 4.620. Can i download one somewhere please?
Please solve
Edited by Ruud
@Ruud Your power adapter may be defective. Try a different adapter, 12V min 4A.
  • 3 weeks later...
I struggle with the same issue. I need to turn the system on and off several times after a powerdip before it will start-up. That's a real issue when I'm not home ;-). Are there any options, other than buy a new HC3?
Or possibly a bad internal CMOS backup button cel .......
see f.i
Edited by jwq
  • 1 month later...
Same issues here. When booting all leds turnes on then after a while only 2 are blue. This morning i had to do 10 reboots before it finally worked.
Changed cmos and it didnt help. Problem occured after the latest update.
as already mentioned this is the failure of the CMOS backup battery onboard. It is easily changeable but it does mean taking the unit apart.
  • 3 weeks later...
I changed the cmos battery, and it functioned again.
  • 1 month later...
Also Changed battery with no result. HC2 loading only after 5-10 manual reboots. 3 light on (power, network, internet).Sad.
Update: It seems that power adapter 12V5A solved my problem. 3 without stucks and rebooting.
Edited by Trr
