Have version: 5.110.15
Tryed to test out the new ZIgbee function, and add IKEA Tradfri.
But only get 502 bad gateway error when starting the Zigbee - add device process.
And it say: "Devices joining process did not start"
If I go directly to the settings for 18. Zigbee, I also get the 502 error popup.
And after x-ing the error, the select channel only say: Current channel: #{{currentChannel}}
Is this a known issue, and any solution to this?
Have tried to reboot and the normal stuff with no help.
Please contact support, they will help you resolve this :)
  • 4 months later...
Hi - Did you get a solution?  I have the same problem and have logged a ticket a week ago with no response..  Cheers
  • 1 month later...
Same issue here. I'm raising a support request. Not the end of the world for me as i was experimenting but want to leverage the tech if possible for simple switching. This thread doesnt fill me with Optimism. ?
/monthly_2022_11/1647804147_Screenshot2022-11-11at12_57_42.png.ec484c5de157670ffddca4895cdb181f.png" />
