fubar 0
I'm trying to use the dimmer module to control a lamp with a standard wall switch. Obviously it's not working, the lamp remains lit when the module is powered and the wall switch does nothing. The red light is blinking on the dimmer 2. I have the bypass installed on the lamp.
Since it's not a direct connection (the cable goes to a 3rd party motion sensor (L2), which in turn is wired to the lamp), I think the dimmer has trouble "communicating" with the motion sensor in front of the lamp.
Is there a way to make it work ?
Here are the schematics
