Fibaro door sensor 1 not recognized well with 4.630
I have temperature sensor attached to my Fibaro door/window sensor 1 with fw 3.2. After upgrading HC2 to 4.630, it stopped reporting the temperature. I ended up by removing and adding the sensor back to network. After multiple attempts (with or without security), same result - endpoint for temperature is not shown. At the end of installation log pointing to some rejection is displayed:
[16:16:13] ID 715: Received association report from group 5
[16:16:17] ID 715: Application rejected request
[16:16:25] ID 715: Device configuration finished
Endpoints 0.1 and 0.3 are visible, I believe missing 0.2 would be the temperature one:
/monthly_2022_05/image.png.9107651eca277cdf23314d5ce66ff0a6.png" />
Any hint how to make the temperature part of sensor available again?
Thx
Jan
