Delete a device that is not visible
Berti
A device is displayed with a number (ID 1) that is not displayed in the overview, how can I delete the device?
8 answers to this question
Device  with ID = 1 is a representation of Z-Wave engine in API, that is why you do not see it and you can't remove it.
  • Thanks for the quick reply, what could be the ID 4?
    Basically I'm trying to figure out was Homebridge showing an error.
    I have disabled all devices and still the error is displayed.
    And only the ID 1 & ID 2 remained over
    ID 2 - its representation of admin (superuser).
    As for device ID4, paste here response from the browser from this url: ip_hc/api/devices/4 and I will answer your question :)
  • Nothing is displayed at 4 but something is displayed at Homebridge Log.
    I do not understand this and slowly I have the feeling that this is the error
    Mmmmmm who says those numbers 1 and 4 are Fibaro Device IDs (EDIT: and related to the errors in red on your picture)? Seems unlikely to me in any case, more like IDs assigned by homebridge...
    Anyway, I noticed text about thermostats and there is this closed issue about the latest HC homebridge plugin
    The relevant part "in version 1.2.4 no support for thermostats. Probably your cached accessories is dirty. Try to remove the specific accessories from it (you can do it via homebridge UI)."
    So something about cached stuff in HB and I cannot help you with that because I don't run homebridge, but my instict told me to look at github.
    BTW I noticed you had the same idea, and posted on github, so I might as well cross reference here:
    Edited by petergebruers
  • Thanks for your help, I found the error. you have to disable the heating schedules under the user
  • You can leave the plans on but you have to give each plan its own name. 😅 😅
    I am glad it is solved. Thanks for reporting back!
