Is there a list of supported zwave engine 3 devices for HC3?
//Sjakie
Generally most of devices works in generic way, all of the parameters templates from old ZW2.0 are migrated to new version.
In some cases of devices (ex old Fibaro RGBW - we are working on it right now) where special handling is necessary due specific implementation devices may behave strange or not work at all.
Only old ZW300 devices may have those issues.
All certified ZW+ modules should work ok.
I have a problem with activating scenes in FIBARO Switch 2 FGS-223 v3.3 . When parameters 28 and 29 are selected, the button configuration does not appear. I have 3 sensors and they all have the same problem.
There is another problem.
When creating block scenes in some rooms, the list of devices is not displayed (photo 1). Аs it was possible to find out, the reason of this fact are some elements of devices. As they are assigned to other rooms, the list of devices in the block becomes available, while in another room, which is fixed to the element of the device, on the contrary.
Example: FIBARO Switch 2 FGS-223 v3.3 has such an element as a remote controller (photo 3, marked as balcony light remote, id 432). When it is assigned to the balcony room, then when creating a block scene and choosing a balcony room, the list for selecting devices becomes blocked (photo 1).
If this element is attached to another room (photo 4, room balcony_S2), the list of devices is available for selection (photo 5). At the same time it is impossible to choose devices already in the room balcony_S2.
This situation occurs with some other devices: The Heat Controller FGT-001, Door / Window Sensor 2 FGDW-002, Roller Shutter 3 FGR-223. Not only elements of the Remote controller were "problematic", but, for example, in The Heat Controller FGT-001 - element Hvac System (system OBKB), or several elements.
Thus diagnostics network Z-wave shows that the network Z-wave is completely adjusted.
Some devices have been resolved by disconnecting and reconnecting devices. But over time, that is likely to happen again. With a Z-wave 2.0 there were no such problems.
  • 8 months later...
changing the language from Russian to another language solves several more problems. if you change the language in the device, everything will be fine.
