Help! I need with triggers of button device in LUA scene
Herni
               Hi Everybody,
               I have a problem. I don´t know how distinguish between two different event triggers (T1 y T2 in the image attachment) of the button device in the same script. Could you help me? Thaks everybody.
                                        Hernán
Edited by Herni
4 answers to this question
Its a long while programming a HC2, but I think you are making a scene for The Button?
I wrote an article about it:
Maybe that helps.
In short:
Catch the event:
And check the presses:
  • Hi Joep,
    Thank for the answer. Great!! I didn´t know about the "keyAttribute" attribute to know how many times was the button pressed. Do you know where i could a document with the FIBARO API´s more complete than the attachment? Thank you very much.
                                                  Hernán
    Use this forum. It's full of knowledge.
    On 5/19/2022 at 8:18 PM, Herni said:
                   Hi Everybody,
                                            Hernán
    In the future to view the trigger's data just
    print(json.encode(fibaro:getSourceTrigger()))
    now you can see the trigger's full data.
