sinds the last fibaro HC2 update 4.630 my push notifications on IOS stopped working.
This is a known error in earlier updates and I hoped that is was fixed, but unfortunalely the problem is back.
Hopefully it can be fixed soon
Push to user fails? Try push to admin?
//Sjakie
Still works ok overhere on the HC2 (and HC3).
This is a known error in earlier updates and I hoped that is was fixed, but unfortunately the problem is back.
Recently have found very strange behavior... if your internet is disconnected for a while or HC2 reboots while no internet, push notifications won't work.
For example after power outage HC2 reboots faster than router... push notification won't work.
Make sure you have stable internet connection and restart HC2.... let me know if it works for you also
By the way this problem exists  for several last releases  (at least for me), I don't remember when it started .
Edited by cag014
    unfortunatly restarting with a stable internet connection did not work for me, but thanks voor your reply.
