skywalker 18
I am looking for a possibility to receive a push notification if on one single switch I have a cumulated consumption more than a certain value in X minutes. Or even better, if consumption is more than ..... for 10 minutes in a row, then push notification.
To understand the situation: SingleSwitch is connected to a waterpump, which is always on and has a pressure switch. However I had the situation that the pump could not reach the upper limit (one way valve blocked open) to disconnect and..the pump was running for almost 1 month without me being able to notice it. Expensive situation.... (pump has 1.3 Kw/h).
I had connected the single switch, if I check from time to time and I see it does not stop the consumption, I can take action. But a push notification would be great to have...
Could not make it myself and here I am asking for help! In theory sounds simple, just could not make it work.
This doesn't work....as the switch is always on... (it gives a message even if no consumption).
/monthly_2022_05/image.jpeg.686525096cae05cb3ef9b2958945f9d3.jpeg" />This "during hour" would be great to use, the consumption (energy panel) for the last hour. Just don't know how to reach this information in a scene...
added pics.
