Aeotec Multisensor 6 No updated parameters
Guest Benrive
When the parameters 41,42,44 are changed (I don't know if some more). The request is sent correctly, but the parameters are not updated.
On receiving the return message, the parameter is always set to 0.
These parameters are essential to reduce the traffic of these multi-sensors.
/monthly_2022_05/image.png.251914f993d26c867997605dcc759ed8.png" />
Edit:
Solved, the solution proposed in this post has worked perfectly.
Thanks' @petergebruers
Edited by Benrive
