Mike MJ 3
I have a Fibaro HC3 and I've set up a Climate Thermostat using a Fibaro Multi Sensor to measure the temperature and a GOAP 1 Relay switch to turn the air conditioner on or off. That works fine.
My problem is that the thermostat turns the air conditioner on and off based on a temperature change of 0.1 Degree C . I'd like to change that to 0.2 deg C . Does anyone know how to do that ?
