Energy panel - How to remove / reset "rest" data?
Dear all,
Love the energy panel concept. Unfortunately I made an error assigning the main energy device, and this created / calculated a large "rest" consumption. (15 MWh !! ) Luckily my house does not consume that much.
In the setting window I "cleared" historical data for my devices and the wrongly "configured" Energy Meter. But the calculated "rest data" remains.
Is there a way to reset this?
The panel looks to be working properly now, it is just a pity that historic data is overshadowing the correct data.
Thanks for any thoughts.
  • 3 months later...
i wonder  this too is ther a fix for this ?
You can clear all energy data via the API. See Swagger: https://hc3-ip/swagger -> DELETE: /energy/consumption
Or send a start- en end period to remove from a specific time:
To send the delete request to delete everything you can use curl (Linux, Windows with WSL):
Or in PowerShell when you are a Windows 11 user:
  • 1 year later...
Guest Jasper Waale
On 10/3/2022 at 1:40 AM, Joep said:
I simpy Cant get this to work, are you able if you have time to more step by step guide ?
Guest Jasper Waale
Yah the API dont work, it looks like missing info
Do you have curl installed? What message do you get? Please give us some more information.
