Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. Completely new and redesigned process of first gateway configuration in WebUi.
2. Added possibility to test newly added Z-Wave devices during first configuration.
What's new:
Dashboard
Added possibility to use Hold (start move) and Release (stop move) actions on buttons in sidebar for roller shutters.
Devices
Device roles now visible on the Settings/Devices page.
Added missing support for devices which works on HC2/HCL platforms.
Added channel designation in the target device selector in Z-Wave association configuration.
Slider for level change for roller shutter with role "Device without positioning" removed from control dialog in mobile application.
Parameter names are now displayed for Z-Wave devices.**
Improved virtual power consumption algorithm for Color Controllers.
Elero*
Improvements in pairing process.
JA Pulse device support added.
Nice*
Changed default devices names to be more understandable.
Improved calibration mechanism for BiDi-Shutter and BiDi-Awning.
Improved error handling during pairing processes.
UI improvements.
Improved removal of disconnected devices.
Other
Device location (room) added to e-mail and push notifications templates.
Updated system packages for performance and stability.
Profiles
Improved saving for actions in profiles.
Quick Apps
Added support for Headers in Websocket connections.
Scenes
Added possibility to rename scenes from within the open editor.
Safeguards have been added to prevent incorrect values being entered in Scenarios conditions.
Performance improvements related to loading elements in Block Scenes.
Added translations for modes and actions for thermostats.
Z-Wave
Added background polling for sleeping devices**.
Improved devices adding process.
Updated SDK to v7.17.2 for Yubii Home and Home Center 3 Lite.
Performance improvements.
Bug fixes:
Dashboard
Redirection to specific device settings not always works correctly.
Elero*
Issue with controlling Awnings in some cases (reversed states and/or actions).
Energy
Wrong rounding up the percentage of summary consumption for devices list in Savings tab.
Issue with "Rest" graph in Detailed Consumption graph in General Tab if main energy meter is set.
Gateway Connection
Empty Z-Wave device templates after downloading them from Slave gateway.
Network
Listing available networks not always works correctly if the currently connected network has poor quality.
Nice*
Added device summary shows default names instead of configured ones.
It is impossible to control old revision of Era Fit BD and Next Fit BD devices.
Inconsistent device renaming during adding wizard in case of different protocols.
Other
Duplicated scrollbar in WiFi search window.
Every logging into the system using mobile application generates redundant events to History.
Profiles
Wrong unit for Sprinklers watering time.
Rooms
Drag and drop the rooms not always works correctly.
Quick Apps
Slider ignores min/max values from the API.
Scenes
Impossible to edit or create scenes using thermostats in Czech language in some cases.
Missing favorite positions condition and trigger for Elero devices.
Z-Wave
ZW300 devices update fails in some cases.
Global polling not always works correctly.
Known issues:
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
